Forums >> Revit Building >> Technical Support >> Turn a 3d max to rfa
Wed, Jan 13, 2010 at 9:58:20 PM | Turn a 3d max to rfa
Thread Post Kudo! #1
Altezza1
Is it possible to convert a max object and make it into a revit family? if so, how....
Thu, Jan 14, 2010 at 11:49:16 AM | Turn a 3d max to rfa
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
export it to dwg then import it into your revit family. it wont be parametric tho.
Sat, Jan 30, 2010 at 9:15:07 PM | Turn a 3d max to rfa
Altezza1
do i just import the cad? so it then becomes a symbol? Is it possible to have the 3d max materials back into that model, or do i need to do it in another method.
Sun, Jan 31, 2010 at 7:05:40 AM | Turn a 3d max to rfa
4 Stars: 205 Votes
Like Alabaster said export to DWG and import in a Family the DWG, the object wont be parametric, check your HELP menu (First image), it wont import the materials you assign in MAX but if in MAX you create the obj. with different layers (colors) you gonna see in the "Materials" several "Render ###.###.###" (second image) and you can change those "renders materials" to a REAL material in Revit....
Also search here in the forum about this issue, there are lots of threads...
DWG 3D TO RFA CONVERSION?
Sun, Feb 2, 2014 at 1:37:21 PM
Systems Furniture RFA Issues
Sun, Aug 21, 2016 at 2:01:34 AM
Revit FBX causes 3DS Max to crash
Wed, Aug 10, 2016 at 6:02:27 PM
render my walkthrough in 3DS MAX
Tue, Apr 23, 2013 at 2:07:40 PM
Revit bring into 3ds Max [ 1 2 ]
Sat, Dec 25, 2010 at 6:24:33 PM
17
Page generation time: 0.1771
