18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Ceiling Heights Scheduled - Problem: Sloped Ceilings
There are a number of helpful posts regarding how to create a parameter in a Room Schedule so that you can have a Ceiling Height variable automatically placed in your Room Schedules. And the problem has been documented that sloped ceilings are a problem. My question is, is there a solution? Is there a way that you can manually change the field inside your schedule to say "Varies" or any other hand fed content from a calculated field? Or, has anyone come up with another work around to this problem? Thanks.
The work around is to use a manual text field instead of an automatic.
Recessed Lights in Sloped Ceiling |
Thu, Dec 13, 2007 at 10:23:28 AM
Ceiling heights in schedules |
Thu, May 26, 2005 at 9:26:42 PM
Lights and Sloped Ceilings |
Mon, Feb 14, 2011 at 4:47:18 PM
Ceiling Plan View Range |
Sat, Feb 23, 2008 at 9:22:53 PM
Annotating high and low points of a sloped / vaulted ceiling |
Tue, Jun 5, 2012 at 1:55:05 PM
