12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> Filled subregion visible on area plan
3 Posts No Rating |
I have an area plan where i need to show a subregion (road) with a solid fill. I can only see the contours of the subregion and no solid fill although this is correctly displayed on a normal plan. On both plans i also have an arial photo. See attached images. I've tried to compare visibilty settings in VV and VP - all the same. Checked Graphics Styles. Turned off color schemes. Tried without foto. Any help/hint is appreciated
easy, solid fill are 2d elements and are view related... just copy clip. same place ...
Joao Cercas
On Revit 2010 (SP3) |
3 Posts No Rating |
Hi Joao Thank you for your reply. I can't copy my subregion there - its a 3D-object and is already there, but ist only the contour that is visible in my areaplan. The solid fill is applied to the material i used for my road and is not a filled region. Regards Claus
4 Posts No Rating |
First of all, if i m clear, the area plan you are talking about is the Site plan actually and you are not able to see the "Solid fill" in Site plan..please clear me if i m wrong...Then you have to adjust only the View range of Site ("area" plan.. Check out the attachment.. If you are creating a Area plan seperatly, what matters most is that, for which level you are creating it...select Level 1 to create an area plan...
3 Posts No Rating |
You saved my day. Thank you. I changede view depth to level below, and resolved the problem. Actually i tried to change the viewdepth before but not enough :-(
Pertaining to the Visibility of Subregion paths. |
Thu, Apr 17, 2014 at 9:52:21 AM
Visibility of Filled Region Boundaries over walls |
Wed, May 24, 2017 at 1:54:59 PM
Toposurface subregion problem |
Sun, Nov 18, 2007 at 4:23:28 PM
Toposurface&subregion problems |
Thu, Apr 16, 2009 at 1:47:06 AM
Area Plan does not match Area from Materia/l Area |
Tue, Feb 13, 2018 at 7:50:03 AM
