Forums >> Revit Building >> Technical Support >> detail component issues
Sun, Jan 10, 2010 at 2:34:47 PM | detail component issues
col9000
Hi,
I'm having a couple of issues with detail components that are probably simple to fix but I can't figure out how... The first is that, when I make line-based detail components, the lines look a lot different in the family editor than they do in the project after I insert them. I'm viewing at the same scale in both cases so that's not the problem. The lines tend to look a lot thicker in the family editor view.
The other problem (more of an annoyance really) is that every time I make a new detail component, or edit an existing one, I have to re-link to the Keynote file (in order to set the keynote parameters), as the path is never saved. Is there some way to set a general path that will always be remembered?
Thanks in advance!
C
Mon, Jan 11, 2010 at 7:31:25 AM | detail component issues
Remember - the project always rules.  The linestyle and lineweight for every line is set in the project and once set, it overrides anything loaded later.  That means the first time you place something that has a new linetype, it is now set to whatever that object's settings are.
You can manage this in the project under settings / object styles.
Embedded detail component scale issue
Mon, Oct 15, 2007 at 10:07:15 PM
Nested Annotation Family in a Detail Component
Fri, Mar 16, 2012 at 8:56:45 AM
CREATING DETAILS USING DETAIL COMPONENT
Mon, Jun 26, 2006 at 4:00:03 PM
Embedded Detail Component and Object Styles
Fri, Feb 12, 2010 at 3:21:25 PM
Text issues with generic annotation family nested into detail component.
Mon, May 19, 2014 at 11:27:43 AM
Page generation time: 4.2704
