23 Users Online (21 Members):
Forums >> Revit Structure >> Tips & Tricks >> Anyone knows how to do a knock-out panel?
20 Posts No Rating |
Hi all! I hope someone can help me out here: I have to draw a knock-out panel in a section. I know how to cut out an opening, on the elevation view. However, Revit's not letting me change depth of the opening from one side to another. I can't seem to angle the cut through the wall. Can anyone help me please?!?! Thanks! L
If you want a partial depth cut, do an in-place void family. BUT the real question is why model this? If you are talking about a section view,just use your edit cut profile tool for each layer of your wall. ORa masking region. NOT everything needs to be modeled.
I can't even do a cut-profile because it involves cutting out in an elevation view (facing the wall) and whatever i cut is going to appear as a straight cut. and i can't change from either side of the wall. I think I may have to do the masked region tool. I'm just thinking that there has to be a better way... thanks!
You first said a section view and now you say elevation view. I still don't understand what you want but the in-place void or just 2D work should solve your problem.
Building Arabic style panel |
Tue, May 26, 2015 at 9:48:09 AM
customerized curtain panel doesn't work with the irreglar shaped panel? |
Sat, Jul 10, 2010 at 1:48:42 PM
Newb Question: Tilt Up Panel |
Fri, Apr 16, 2010 at 1:00:49 PM
12
Electrical Panel Schedule |
Tue, Sep 14, 2021 at 9:18:20 AM
Scheduling Revit MEP Panel name and circuits |
Fri, Nov 11, 2011 at 2:29:52 PM
