Forums >> Revit Building >> Technical Support >> Elevations and Axonometrics not displaying correctly.
Thu, Jan 7, 2010 at 4:55:05 PM | Elevations and Axonometrics not displaying correctly.
Snodaisy
Revit 2009
Hi. I am looking for tips/tricks to correct views that are displaying incorrectly. Foremost, an elevation that is dropping an outside line. It is a line defining the edge of radius piece. The line initially renders, but when I scroll it disappears for good. Would assume Revit (especially 2009) may not have the engine to handle small curves, however anyone find a solution to this?
The second is of an axonometric that is showing lines of elements that are hidden. The view is set to "Shading with Edges." It is a complicated piece, but again.... solutions?
Much Appreciated!!!
Building axonometrics
Fri, Oct 12, 2007 at 4:42:50 PM
Gutter not displaying correctly in elevations
Mon, Jan 17, 2011 at 1:24:41 PM
2015 CURVED WALLS NOT DISPLAYING IN REVIT CORRECTLY
Fri, May 6, 2016 at 9:21:20 AM
3D Model not displaying correctly.
Tue, Jun 10, 2008 at 5:15:36 PM
Thickened Slab Edge not displaying correctly.
Tue, Sep 2, 2008 at 9:50:37 PM
Page generation time: 0.8658
