Forums >> Revit Structure >> Technical Support >> Dependent Views
Thu, Jan 7, 2010 at 10:14:52 AM | Dependent Views
TONY121
On the current project that I am working on the build must be split in half, requiring me to use the matchline tool and putting half of the building on one sheet and the other half on another sheet. No big deal I know but I have dimensions between gridlines and I need them on all sheets. Is there a way for me to have dimensions shown on all sheets without having to place them on each side of the building?
Mon, Jan 18, 2010 at 2:52:21 PM | Dependent Views
ollienz
ollienz Avatar
what you should do is create a duplicate with detailing of all the current floor plans you must already have.
Then apply a view template to these new copies that sets them all to the scale you need for your enlarged plans.
then for each view, create two dependant views from it, and alter them using your matchline tool to fit half on a sheet. put all your dims etc on the parent drawing, and it will then transfer onto the dependant halves.
Mon, Jan 18, 2010 at 4:27:38 PM | Dependent Views
You will have to have two strings - one on each side of the split.
Dependent views not the same as Parent view...
Fri, Jun 16, 2017 at 11:02:18 AM
Detail Callout Bubbles and Dependent Views
Thu, Aug 12, 2010 at 6:51:10 AM
Design options and dependent views?
Wed, Nov 4, 2009 at 8:26:39 AM
filled region in dependent views
Fri, Feb 22, 2008 at 6:53:39 AM
Collaboration and dependent views
Fri, Jun 9, 2017 at 10:14:43 AM
Page generation time: 5.1771
