Forums >> Revit Building >> Technical Support >> CALLOUT DETAIL VIEW VS. PLAN VIEW
Thu, Jan 7, 2010 at 9:47:36 AM | CALLOUT DETAIL VIEW VS. PLAN VIEW
Vanessa22
I've blown up my floor plans using the callout "detail" view, but realized too late that I should be using the callout "plan" view instead. Now I cannot insert any elevation bubbles in my blowups becuase they are detail views. is there any way of changing the callout detail view to a callout plan view without re-drawing them?
Thanks
Thu, Jan 7, 2010 at 10:05:10 AM | CALLOUT DETAIL VIEW VS. PLAN VIEW
You don't really have to redraw.  If you want to switch callout types, create a new callout then window everything in your detail view, flter it removing all model elements, copy to clipboard then switch to your plan view and paste-same place.  Now delete your old view and place your new view in its place on your sheets.
Wed, Mar 10, 2010 at 2:04:47 PM | CALLOUT DETAIL VIEW VS. PLAN VIEW
Skaf
I don't suppose there is an easy way to switch all the views that refer to the detail view so that they refer to the new plan view instead?
I'm using Revit 2009 for this project by the way.
How do I show a detail callout in more than one view?
Thu, Oct 7, 2010 at 1:22:09 PM
Help with visibility of components and detail lines in plan view and callout?
Tue, Nov 27, 2007 at 1:12:14 PM
Creating an Enlarged Detail View of a Detail I have Drawn
Fri, Aug 31, 2012 at 7:05:29 AM
Callout: Detail view vs. Building section RAC 2008
Mon, Sep 24, 2007 at 2:05:38 PM
Detail Component visibility from wall section to detail callout view.
Thu, Oct 8, 2009 at 3:54:42 PM
Page generation time: 1.2012
