Forums >> Revit Systems >> Technical Support >> Outlet placement problems
Wed, Jan 6, 2010 at 12:08:34 PM | Outlet placement problems
3YLSYKR
3YLSYKR Avatar
I have the placement height of my hospital grade  tamper resistant safety outlets at 4'-6" but it shows up in the rcp because the elevation was set to 4'-6" also. I drop the elevation down a little and you can then see it in the working floor plan but drops the outlet lower than I want even with the placement height at 4'-6". How do I get it to show in the working floor plan at 4'-6" and not the rcp.?
AutoCAD 2001-2009
AutoCAD MEP 2009-2010
Revit 2008-2009
Revit MEP 2009-2010
Navisworks Freedom 2009
Trimble LM80 Desktop
Wed, Jan 6, 2010 at 2:21:28 PM | Outlet placement problems
Your floor plan at 4'6 sounds a bit low.  Most of us set it just below door height.  And your ceiling plan at 4'6 is way too low for me because all your doors show.  We usually just set that above the door height.
Any family cut or within the view range will show.  You can always turn off categories in VG or select all instances and hide in view for those elements that still show when you don't want them.
Outlet families
Tue, Jul 17, 2007 at 11:49:40 AM
add height label to outlet symbol (2019)
Mon, Feb 22, 2021 at 11:46:51 AM
Label in Outlet-GFI Family Revit 2009
Tue, Jan 27, 2009 at 1:38:11 PM
Ceiling Mounted Outlet
Tue, Sep 26, 2006 at 1:57:22 PM
Duplex outlet dimensions
Tue, Nov 27, 2007 at 1:44:52 PM
Page generation time: 0.6812
