Forums >> Revit Building >> Technical Support >> Post purge component problems
Tue, Jan 5, 2010 at 10:35:45 PM | Post purge component problems
spohler
I am a new user using Revit 2010. I had a bunch of components loaded that I didn't need. So I purged unused. But when I did I accidentally purged unused that I want to use now. But they will not re-load. I can load families that have never been loaded into the project but any family that was in the project, then purged will not re-load. Help!
Wed, Jan 6, 2010 at 6:47:01 AM | Post purge component problems
Are you really reloading a whole family or are you just missing a type?
What family is it?  Sweeps. gutters, facias, cornices and reveals need profilesand then have to be defined in the project using those profiles.
Wed, Jan 6, 2010 at 11:57:09 AM | Post purge component problems
spohler
I am trying to load Conifer Trees and one of the Pendant light types. I click the component button then load family button. As I said before I can load other lights and trees and anything else I like as long as it was not loaded into the program before.
Thu, Jan 7, 2010 at 10:53:34 AM | Post purge component problems
cbieser
1 Stars: 1 Votes
Try opening the family file independantly of your project (keep your project open) and then click Load into project.  When it asks you if you want to overwrite click yes.
purge issues
Mon, Jun 16, 2008 at 11:26:22 PM
Purge Command - possible to purge family types accidentally?
Tue, Aug 20, 2013 at 12:01:08 PM
Text style that I can't get purge
Wed, Sep 5, 2012 at 8:40:41 AM
purge selected
Wed, Sep 17, 2008 at 10:40:42 PM
LOADING COMPONENT [ 1 2 ]
Sat, Apr 11, 2009 at 5:30:13 AM
24
Page generation time: 0.7964
