Forums >> Revit Building >> Technical Support >> Lining elements
Tue, Jan 5, 2010 at 7:52:17 PM | Lining elements
col9000
Hi,
Does anyone know the best way to create a lining on an existing, complex surface?A t the moment I have to do this in 2 places. I have a complex roof shape, and I would like to:
1. Line part of its inside face with plasterboard (it slopes in a few directions, so using the "ceiling" tool would be very tricky) and
2. Line part of its external face with a layer of extensive green roof
The roof is face based, so there is already a mass set up to create its shape.
I'd appreciate any advice, thanks!
Colin
Door Lining Depth
Thu, May 3, 2007 at 2:39:56 AM
Cant find ductwork lining settings and fitting settings.
Tue, Apr 7, 2009 at 10:44:56 AM
Drawing displaying size of same elements different and also off-centre
Sun, Dec 2, 2007 at 2:48:21 PM
Advice on wall linings
Fri, Oct 27, 2017 at 2:04:59 AM
Insulation and Lining thickness for ductwork issue
Wed, Mar 11, 2009 at 9:41:18 AM
Page generation time: 2.0409
