Forums >> Revit Building >> Technical Support >> Curtain wall Panels attached to Core Wall
Tue, Jan 5, 2010 at 7:38:37 PM | Curtain wall Panels attached to Core Wall
Mixaeel
Mixaeel Avatar
Is there any solution for attaching the curtain wall panels to main wall, concrete core in this case.
I tried making genuine storefront  and changing the curtain panel to desired wall type with finish face exterior I want. The problem than is the system who cuts through the core part.
  http://yfrog.com/iy1cutcorej
What I am trying to do here is to make system panel for my exterior face and than attached it to core wall
http://yfrog.com/132cutj
   http://yfrog.com/jq3a3j
Any help appreciated, thank you.
Wed, Jan 6, 2010 at 3:47:36 AM | Curtain wall Panels attached to Core Wall
4 Stars: 205 Votes
Create the Curtain wall "Inside" the main wall BUT in the properties of the curtain wall you have (in edit/new) an option "Embeded wall" (i think this is the exact name, i don't have revit here), turn this option ON and it's done....
Curtain wall panels following profile
Wed, Oct 12, 2011 at 8:41:57 AM
Curtain wall panels not trimming correctly against mullions
Thu, Dec 10, 2009 at 5:49:55 PM
Panels with Different Finishes on Same Wall
Mon, Jul 8, 2013 at 9:19:13 AM
Curtain wall panels changing materials when pinned
Fri, Feb 26, 2010 at 8:46:05 AM
panels dont update on Curtain wall length
Sat, Aug 16, 2014 at 8:20:44 AM
Page generation time: 1.2772
