Forums >> Revit Building >> Technical Support >> Worksets: Copying from one drawing to another?
Tue, Jan 5, 2010 at 11:01:46 AM | Worksets: Copying from one drawing to another?
3YLSYKR
3YLSYKR Avatar
Let's say I open the central file, and create a new local file. How do I copy worksets from another older local file to the new one and keep the colors and settings I had for each one all associated correctly with each item?
I'm hoping there is a way so I don't have to re-set up the worksets after copying the families from drawing to drawing.
AutoCAD 2001-2009
AutoCAD MEP 2009-2010
Revit 2008-2009
Revit MEP 2009-2010
Navisworks Freedom 2009
Trimble LM80 Desktop
Tue, Jan 5, 2010 at 11:05:49 AM | Worksets: Copying from one drawing to another?
Locals are just copies of the central and the two are the same when updated.
Tue, Jan 5, 2010 at 11:15:01 AM | Worksets: Copying from one drawing to another?
3YLSYKR
3YLSYKR Avatar
Not when one of the locals are not linked and only one local file has the families loaded and worksets set up in the drawing.
 How do I copy worksets?
AutoCAD 2001-2009
Revit 2008-2009
Revit MEP 2009-2010
Tue, Jan 5, 2010 at 11:24:37 AM | Worksets: Copying from one drawing to another?
You are missing the concept of Revit.  ALL LOCALS ARE LINKED THROUGH THE CENTRAL FILE.
All you have to do is update the central file and that will reload latest.  If user A creates a workset then saves to central and then user B either reloads latest or saves to central, user B will now see the workset.
Tue, Jan 5, 2010 at 11:44:50 AM | Worksets: Copying from one drawing to another?
3YLSYKR
3YLSYKR Avatar
I am not missing anything. One local is linked to a central. That local has nothing on it, blank local made from the central.
 I have another local file not linked to any other file or central with worksets on it.
I want to copy the worksets from the non linked local to the linked local.
I tried linking the central to it, saving and what not and then updating the already linked local and nothing happened or worked. Do you understand what I'm saying better now?
AutoCAD 2001-2009
Revit 2008-2009
Revit MEP 2009-2010
Tue, Jan 5, 2010 at 11:48:06 AM | Worksets: Copying from one drawing to another?
Please read your HELP - Start with this topic Using Workshared Files
Tue, Jan 5, 2010 at 12:48:44 PM | Worksets: Copying from one drawing to another?
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
I think we need clarification here as things are not adding up.
In order to have a local file, it has to be generated from a workshared enabled central file. The "link" that Hub is talking about is really nothing more than constant chatter between the two files passing bit information as it changes and so on.
That "link" is what allows for the borrowing of elements and file updates and is not to be confused with Revit's "LINK REVIT" command as they are not the same.
From that standpoint, what Hub is saying would be all you need to do, Sync with Central and any new worksets will pass to ALL local files.
But you are saying that you have a local file created from a central, and another local file that is "not linked to any other file or central with worksets on it."
And there lies the confusion as you cannot have a local free from a central file unless it was detached from central...and even then, it will still maintain worksharing and just become a central file.
If you have two local files generated from the same Central file, simply do a sync to central from the local file that has the worksets desired, then reload latest from the local that needs the worksets.
 To me it sounds like you want to take the worksets from one project and copy them into a new unworkshared file.
Worksets cannot be copied that I am aware of so if that is the case, I would consider remaking them or open the other local file detached, delete everything and start from there.
The more information you can provide, the better we can help.
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Tue, Jan 5, 2010 at 1:27:09 PM | Worksets: Copying from one drawing to another?
3YLSYKR
3YLSYKR Avatar
I had local made from a central. I did some work. I got a new updated central file and saved over the top of the existing central file. As far as I knew the local was linked to the central. There were some errors or problems that came up so I made a new local file and thought I could copy the work from one to another. I guess you can copy families and stuff but not the worksets. Yeah the previous local is detatched I believe.
When I open it with the file open type command it opens the local with the create local box checked and puts a new local file in the My Documents. If I just click the image to open the drawing it doesn't create one. I finding how things work are pretty interesting.
Looks like I'll have to re set up work sets after copying families over or just keep the first local detatched as my current local and link to central and work that way.
AutoCAD 2001-2009
Revit 2008-2009
Revit MEP 2009-2010
Tue, Jan 5, 2010 at 4:41:43 PM | Worksets: Copying from one drawing to another?
I'm sorry but it still doesn't sound like you understand this process.
Once you enable worksets, you create a central file on your network then you create a local file and save it to a local directory.  Once that is done, you never have to save a central file again.  You do not overwrite the central file!
While in your own local file, you simply synchronize with central and that publishes your changes to the project while it downloads to your local any changes that were published by other users.  At the end of the day, publish your changes, save your local file and close.  Start up your next session by opening your local - reload latest and you are up to date!
Tue, Jan 5, 2010 at 4:53:39 PM | Worksets: Copying from one drawing to another?
3YLSYKR
3YLSYKR Avatar
I understand how all that works.
Tell me the best way to update the central file then with a new one when I get it and be able to keep my safe stuff on local. Should stay if i'm linked right?
AutoCAD 2001-2009
Revit 2008-2009
Revit MEP 2009-2010
Clearing a drawing of Worksets
Sun, Jun 18, 2006 at 9:19:38 PM
Worksets
Mon, May 23, 2005 at 9:25:16 PM
Help: Copying families from one drawing to another
Mon, Apr 21, 2008 at 3:27:22 PM
Cant Delete one of My worksets...please help
Thu, Feb 14, 2019 at 1:48:12 PM
13
cannot enable worksets
Tue, Jan 23, 2018 at 11:00:18 AM
13
Page generation time: 0.7406
