19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> big problem with edit cut profile????
31 Posts No Rating |
I found problem using edit cut profile tool.
Everything is OK when I use it in plan view, but in the case of using plan region with different range of cut plane my edit cut profile just doesn’t work it turns green and report some error.
I’m using Revit 8 build 20050620_2300 demo version and I’m in learning phase of this nice software which should replace our 2 ADT 2006 in my office.
What is the "some error".
Ends of the sketched loop do not lie on the boundary of the face being modified.
But I did sketch properely.
69 Posts No Rating |
What are you trying to create with the edit cut profile?
Okay you've got me too.
What are you trying to show?
The cut profile you've drawn isn't even cutting the wall, or have you done this to show what you want to happen? Please explain...
Forget my stupidity, I had some problems with one wall join and wanted to alter its shape. Now everything is OK.
My mistake!
Edit Cut Profile |
Tue, Dec 20, 2011 at 6:00:24 AM
edit cut profile |
Mon, Aug 2, 2010 at 1:18:58 PM
Edit cut profile line thickness |
Wed, Nov 18, 2009 at 12:15:27 PM
Edit cut profile lineweight display issues |
Wed, Mar 7, 2007 at 10:23:48 AM
metal deck cut profile |
Thu, Nov 4, 2010 at 9:17:43 AM
