Forums >> Revit Structure >> Technical Support >> Revit Extensions for Revit Structure 2010
Tue, Jan 5, 2010 at 10:28:04 AM | Revit Extensions for Revit Structure 2010
Steve123
I'm using the Revit Extensions for Revit Structure for my individual plan notes. When I drop them in my sheet from the detail view, a note title is produced that I don't want to appear. That title is the name that I gave the detail view. I tried to use hide in view > element, but I don't have the ability to choose that function. Is this the easiest may to insert plan notes from a Word document?
Tue, Jan 5, 2010 at 10:49:01 AM | Revit Extensions for Revit Structure 2010
Steve123
Never mind I found out how to do it.
Tue, Jan 5, 2010 at 12:36:07 PM | Revit Extensions for Revit Structure 2010
4 Stars: 205 Votes
Steve, why don't you put here the answer for Future??? if the other guys has the same problem they could read this same thread and find the answer too....
Tue, Jan 5, 2010 at 1:02:10 PM | Revit Extensions for Revit Structure 2010
Steve123
Typhoon,
 I'm new at revit and I don't want to publish a reply until I knew that the solution I found doesn't produce other problems down the road. Case and point, When I first dragged and released my mouse button to drop the detail view of my plan notes (created by the Revit Extensions program) into the sheet I found that this is the time you can click on the note title and use hide in view > element. If you click outside the note window or hit Enter (completing the drag and drop process) the "note title" cannot be removed or hidden. By using the hide in view > element command the "note title" is now gone but now I want to shift the plan notes and I can't select them at all. Help.
revit extensions
Sat, Jan 24, 2009 at 5:41:56 AM
Revit Extensions
Mon, Jun 29, 2009 at 6:12:52 PM
RSA 2010 problem
Thu, Apr 23, 2009 at 1:13:37 AM
Looking for Revit Structure Extension Text Generator
Mon, Jan 24, 2011 at 2:11:22 PM
Revit Extensions for 2012?
Fri, May 6, 2011 at 10:52:35 AM
Page generation time: 1.7296
