11 Users Online (9 Members):
Forums >> Revit Structure >> Technical Support >> View at an angle
6 Posts No Rating |
Hello, I am new with REVIT, currently using REVIT Structures. I have a concrete wall that is at an angle (model in place, blend) and I want a view perpendicular to a face of that wall for the placement of some dimensions. How can i make a (section) view that is looking down at an angle? An elevation is always a vertical plane, and a section is also always vertical if it is drawn in an elevation view or an other section; I really need a workaround. Huibert
Whilst a section when initially drawn is vertical, you can rotate it afterwards to any angle you like. Also a detail section can be drawn at any angle you wish, however certain things don't display in detail views so I tend to avoid them...
Regards,
Chris.
6 Posts No Rating |
Thanks Chris, This was the answer I was looking for. Huibert
Iso view angle |
Mon, Feb 6, 2012 at 3:27:41 PM
saving 3d view camera angle |
Fri, Dec 30, 2016 at 7:16:40 AM
saving 3D view? |
Fri, Jan 9, 2009 at 8:59:55 AM
Rotation angle of double angle roof bracing. |
Mon, Jan 21, 2008 at 2:51:55 PM
Adjustable Angle Reference Gets Lost once a 90 Degree Angle is Formed... |
Wed, Sep 30, 2015 at 12:28:52 PM
