23 Users Online (21 Members):
Forums >> Revit Building >> Technical Support >> Revit 2010 - Keynoting dependent plans
28 Posts No Rating |
Hello all, Because of the size of our project we have enlarged partial plans (Plan A and Plan B) on which we are doing our keynoting. These partial plan views are set up as dependent to a master plan. I'm keynoting by sheet and have not had problems placing the key notes, but when I go to place the keynote legend on the sheets, the legend lists all key notes used between the two partial plans (I assuming because they are dependent). For example, a refidgerator is listed on the legend for plan A when that item exists only on plan b. This wouldn't be a huge problem for us, except since we are keynoting by sheet, it lists it at the bottom as a completely difference number from the actual keynote on plan b. Makes for very confusing drawings! Any suggestions on how to alliviate this? I really appreciate it! I really want to avoid having to recreate the views as independent!
If you are keynoting by sheet, you may want to go into the filter dialog of the keynote legend and check the box at the bottom for "filter by sheet" This way it will only display the keynotes relevant to the sheet. HTH
Unfortuantely I've already set it to filter by sheet, but I still get the key notes from the other dependent plan. Thanks for responding though...
Revit 2010 Keynoting |
Tue, Oct 4, 2011 at 5:42:57 PM
Matchlines and Duplicate Dependent Views |
Thu, Nov 29, 2007 at 8:01:42 AM
Overall Plans and Partial Plans ... looking for Best Practice [ 1 2 ] |
Sun, Jul 21, 2019 at 7:44:21 AM
15
Dependent views not the same as Parent view... |
Fri, Jun 16, 2017 at 11:02:18 AM
Keynoting WHAT TO DO? Revit 2010 |
Mon, Apr 5, 2010 at 3:46:31 PM
