Forums >> Revit Building >> Technical Support >> corner trim
Fri, Mar 5, 2004 at 10:26:30 AM | corner trim
Pyxis55
How does one add corner boards to a model? I'm up here in New England where most houses are clapboard, and I'm just getting into adding trim to the exterior. How do I model complex soffits, and returns and fascias?
Karen Maxon LineWright
Fri, Mar 5, 2004 at 1:00:15 PM | RE: corner trim
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
Karen, it would probably serve you better to ask more specific questions about one thing at a time. Try asking how to model a certain kind of fascia or whatever. thanks,
Hiroshi Jacobs
The Catholic University of America
Fri, Mar 5, 2004 at 1:39:18 PM | RE: corner trim
Pyxis55
What is the best method for adding corner boards to a model? I've used a simple extrusion, but thought there might be a preferred method. Thanks, Karen
Fri, Apr 2, 2004 at 2:17:39 PM | RE: corner trim
lateralus
You can use a vertical wall sweep. Create a profile of the piece of trim that you want to make and use that for the sweep. Then just go around, add the sweep and voila - corner trim.
Corner Trim with Vertical Sweeps
Thu, Aug 31, 2017 at 2:32:51 PM
trimming trim corner.
Wed, Feb 1, 2012 at 12:09:41 PM
trim/extend to corner
Thu, Nov 4, 2010 at 6:10:31 AM
Help! Forgot how to trim with a radius corner.
Mon, Jan 8, 2007 at 8:25:35 AM
Sweep Corbelling Trim on the Corner
Fri, Apr 8, 2016 at 1:04:26 AM
Page generation time: 2.2637
