Forums >> Revit Structure >> Technical Support >> Creating Existing Footings in Revit Structure
Sat, Jan 2, 2010 at 6:50:19 PM | Creating Existing Footings in Revit Structure
mike321
I need to create existing footings under the architect's revit model on my first project. Even though these walls are not a part of the new construction, should I use the Structural Wall command then duplicate and create a new wall type as "Existing Foundation Wall 12 Conc". Then should I do the same with the existing wall foundation duplicating and creating a new "Existing Wall Foundation 36"x12". After that i could use halftone make them appear light. Is this the easiest way?
Mon, Jan 4, 2010 at 12:09:19 PM | Creating Existing Footings in Revit Structure
pdoug
3 Stars: 2 Votes
Actually Revit will take care of the difference.  What I usually do is create a new wall type if I need to tag it differently from one that is new construction...otherwise just select the elements which will be "existing" and go to the element properties...under Phasing>Phase Created, select "Existing".  It defaults to new construction.
Hope this helps!
Revit Structure 2011 view question
Fri, Aug 13, 2010 at 3:58:48 PM
Question about elevating footings
Mon, Feb 1, 2010 at 2:31:35 PM
Footings for Slab Foundation
Tue, Oct 30, 2007 at 7:05:08 AM
Auto Footings
Tue, Apr 4, 2006 at 10:10:15 PM
Footings, getting double hidden lines and intersections suck!
Fri, Aug 31, 2012 at 10:13:08 AM
Page generation time: 3.7829
