Forums >> Revit Building >> Technical Support >> Render transparent material
Thu, Dec 31, 2009 at 3:58:52 PM | Render transparent material
marquezc
Can anyone offer advise on rendering a fabric material to have translucent properties? I see that you can edit the transparency and translucency but I am still not getting the results I need. I am trying to render a fabric that is tranparent to enough to allow light to pass through but not so transparent that it is clear.
Chas Marquez, LEED AP
Mon, Jan 4, 2010 at 7:32:55 AM | Render transparent material
MARS1276
1 Stars: 1 Votes
Have you tried applying the material as "Glass" and add the color and transparency that way?  I know you are looking for fabric material, but if you may be able to get the desired look to it that you are wanting.
Creating transparent material such as 3FORM
Wed, Aug 26, 2009 at 8:09:06 AM
MAKING DEMOLISHED OBJECTS TRANSPARENT
Tue, Mar 12, 2013 at 2:02:34 PM
Transparent Window Frames in 3D render when camera view angled
Thu, Apr 23, 2009 at 8:42:11 PM
TRANSPARENT MATERIAL SHOWING IN 3D
Wed, Mar 6, 2013 at 3:16:18 AM
Adding new render material
Wed, Nov 2, 2011 at 10:39:45 PM
Page generation time: 1.8937
