Forums >> Community >> The Studio >> how create own pattern file (*.PAT)
Sat, Sep 3, 2005 at 5:48:03 AM | how create own pattern file (*.PAT)
cnevians
yes want to create some pattern file but we haven't got autocad only revit and illustrator CS1 can't do PAT file .... so some idea ?
NEVIANS Cedric Architecte DPLG Revit 2011 French User France
Sat, Sep 3, 2005 at 11:25:43 AM | RE: how create own pattern file (*.PAT)
TomDorner
4.5 Stars: 25 Votes
Hatch patterns are nothing more than text files. You can create them in a text editor, or using special software to make the task easier. It is easier (ce facil) to find a pattern that someone else has created. There are many patterns on this site and since the file uses the same format as AutoCAD (with the addition of a new line) you can find them everywhere. Software to create hatch: http://www.cadro.com.au/hatchkit/ Hope this helps (HTH) Tom
Sat, Sep 3, 2005 at 3:59:10 PM | RE: how create own pattern file (*.PAT)
cnevians
thanks .. jusr search this ... yes can download lot of PAT file on the net... but sometimes can run in revit... (model or sketch ...) thanks for reponse
Sat, Sep 3, 2005 at 7:21:09 PM | RE: how create own pattern file (*.PAT)
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Its simple to edit any existing pattern to make it either model or drafting and also to set a scale. You just need to add the following information in the pat file using a text editor. ;%UNITS=MM - To set the units ;%TYPE=MODEL - To set the type, entry DRAFTING if not model. HTH.
Mon, Sep 5, 2005 at 1:36:55 AM | Chk out my new work in flash
spot4000
Hello I like to forum spam a lot and I just did this, so the site moderator came in here and edited my post to this. Post edited on 2005-09-05 23:48:18
Mon, Dec 17, 2007 at 4:52:16 PM | how create own pattern file (*.PAT)
Jhui
I tried adding the ;%TYPE=MODEL into the .txt file and it never worked for me. Any more direction that I can receive?
Tue, Dec 18, 2007 at 7:46:17 AM | how create own pattern file (*.PAT)
Not sure what your problem is. Here is an example that does work:
*10.5x15 Stretch running bond
;%TYPE=MODEL
0, 0,0, 0,10.5
90, 0,0, 10.5,7.5, 10.5,-10.5
Edited on: Tue, Dec 18, 2007 at 7:50:09 AM
Edited on: Tue, Dec 18, 2007 at 7:50:34 AM
New pat pattern help
Tue, Nov 1, 2011 at 8:26:43 AM
Pattern (.PAT) Files
Mon, May 3, 2021 at 4:51:04 PM
Stray Lines in custom Revit fill pattern
Mon, Jul 8, 2013 at 8:02:44 AM
Import PAT File
Tue, Dec 14, 2010 at 9:42:43 AM
Split Faced CMU model material pattern help???!?!?!?
Fri, Jun 1, 2007 at 2:01:39 PM
Page generation time: 2.3093
