Forums >> Revit Systems >> Technical Support >> Dimensioning pipe in 3d
Tue, Dec 29, 2009 at 12:27:51 PM | Dimensioning pipe in 3d
GMMcCrossin
Is it possible and if so what do i need to do.. I can dimension but it always drops to a lower elevation. I was hoping that it would stick to the pipe i selected?
Wed, Dec 30, 2009 at 10:01:49 AM | Dimensioning pipe in 3d
anna2004
4.5 Stars: 3 Votes
It is really not easy to dimension in 3D. You really need to make sure the dimensions are right.
Dimensioning tolerances to use align dimension with grid lines ?
Tue, Feb 9, 2016 at 11:18:30 AM
Trim HSS Round pipe into another HSS Round pipe
Tue, Apr 3, 2012 at 4:39:45 AM
pipe dimensions
Wed, Dec 2, 2015 at 7:47:03 AM
Pipe Accessories and Pipe Type parameter
Tue, Dec 27, 2011 at 11:25:39 AM
Pipe Branch Takeoff/Gain
Fri, Feb 26, 2016 at 12:29:37 PM
Page generation time: 0.7255
