Forums >> Revit Building >> Technical Support >> Family re-load
Mon, Dec 28, 2009 at 10:13:23 PM | Family re-load
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
RAC 2010
When a Family is re-loaded into a Project,many of the Parameter settings are not updating.Some recent examples that I've encountered are:1. the Material Parameter values of Nested Family Types.2 the Parameter values in the Parent Family Types.I've had to edit the nested Component Family Types within the Project to fix issue #1,and likewise I had to edit the parent Family Type Parameters within the Project to fix issue #2.Why don't these Parameters update upon a re-load of the Family into the Project?
Tue, Dec 29, 2009 at 7:39:53 AM | Family re-load
For material settings, the project always rules...period!
This really makes sense, if you think about it.  You don't have to modify families to change material settings in projects.  So this means that once the material is set in a project, you will have to modify it at the project level.
Cannot load family
Mon, Apr 18, 2011 at 5:22:02 PM
Reivt will not load door family
Tue, Oct 11, 2011 at 7:23:13 AM
the load in family not working
Fri, Aug 19, 2016 at 1:01:12 AM
Load Family button does not pull open the file browser
Wed, May 4, 2011 at 1:55:38 PM
Revit Cannot Load Family
Mon, Aug 1, 2011 at 7:20:35 AM
Page generation time: 1.9937
