Forums >> Revit Building >> Technical Support >> Revit 2010 printing random lines
Mon, Dec 28, 2009 at 12:28:18 PM | Revit 2010 printing random lines
rich08
I'm having trouble printing maybe someone can help me out. I have Revit 2010 and running on Windows 7 and the printer we are using is a KIP3000.
Whenever i print from revit/pdf/dwf i get random lines that print on the sheet it doesn't show on the preview but it shows on the sheet. Also some sheets come out fine and others have random lines. Has anyone else have this problem? Any help is appreciated. Thanks
Mon, Dec 28, 2009 at 12:40:00 PM | Revit 2010 printing random lines
Warchitect
4 Stars: 5 Votes
Have you tried to make a PDF file first. then just print to your kip with Adobe reader.
Some printers have problems with the hatches and fills (if your using any).
Mon, Dec 28, 2009 at 1:05:26 PM | Revit 2010 printing random lines
rich08
Yeah i tried printing it to a pdf/dwf first it looks good on the preview but when it plots it still has the lines.
alot of this started when we switched to Windows 7.
Mon, Jan 4, 2010 at 10:51:09 AM | Revit 2010 printing random lines
amandaholly
I had this problem too - or a similar one.  Printing to PDF I would get random lines  that did not show up in the preview.  Can't remember which it was but it had to do with printing raster or vector.  Changing the setting fixed it.
Random Elevations Not Printing
Tue, May 20, 2014 at 9:02:54 AM
Room Color Fill Not Printing, Random Circle is
Wed, May 17, 2006 at 6:20:12 AM
Revit 2010 Printing Problems [ 1 2 ]
Wed, Jun 24, 2009 at 11:21:31 AM
16
Random Walls not printing the Pattern
Thu, Feb 20, 2014 at 9:21:34 AM
some keynotes not printing
Thu, Sep 15, 2016 at 4:43:39 PM
Page generation time: 1.7947
