Forums >> Revit Building >> Technical Support >> how to create a wall niche
Wed, Dec 23, 2009 at 9:41:58 AM | how to create a wall niche
jackalvn
I'm new in using Revit and can not find a way to create a niche in a wall.
Hope your help.
Thanks for your care!
Wed, Dec 23, 2009 at 9:49:12 AM | how to create a wall niche
You could do an in-place wall void or create a wall hosted niche family that has a void in it to cut the host
Fri, Dec 25, 2009 at 7:32:57 AM | how to create a wall niche
jackalvn
Thank for your tip
I thought the same way but it didn't show as i wished until I found out that after placing void in the wall family, you need to use cut geometry. Some experiences for ones who may run into the same matter.
But I face another matter: the wall niche created by using void don't have material like the walls enclose it, it receives material as structure material of the host wall.
Could you tell me how to get a finished material for the wall niche as the host's?
Sat, Dec 26, 2009 at 7:22:18 AM | how to create a wall niche
4 Stars: 205 Votes
Use the "Paint" tool to do that....
Sun, Dec 27, 2009 at 5:11:57 AM | how to create a wall niche
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Or more accurately, include the finish structure in the family model...
Regards,
Chris.
Wall Niche
Fri, Mar 29, 2013 at 7:38:32 AM
Cut extrusion
Wed, Aug 31, 2005 at 6:03:22 PM
Any brains out-there?
Thu, Jan 22, 2004 at 8:33:27 PM
help me!
Tue, Mar 10, 2009 at 11:21:21 AM
Niches instead of Infills
Fri, Sep 19, 2008 at 11:23:22 AM
Page generation time: 1.2446
