37 Users Online (35 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Multi axis curtain grid
Wed, Dec 23, 2009 at 9:24:32 AM | Multi axis curtain grid
Atraktzi
Hi there,
I need to model a complex shape that is based on a flat grid wrapped around an amorphous object.
Each panel is fairly complex, but the grid itself is the hard part as it has 3 directional axes.
Each axis is 60 degrees from the next (see attached PDF).
The plan is:
  • set up this grid somehow (fixing the grid line problem & modelling the panel)
  • create parametric blob
  • create a curtain system by face
  • ...and now i have a parametric curtain system (that will no doubt give me a 100 errors when i try and edit a parameter Puh)
Anyway, my main issue (well... the first one) is this non cartesian grid.
I attached a PDF of the flat grid, and a photo of a physical model of the result...
Thanks to anyone who reads this, and more to anyone who can help!
Adam (5th year architecture student)
Wed, Dec 23, 2009 at 9:27:00 AM | Multi axis curtain grid
Atraktzi
Hmm photo didnt get accross...
curved curtain system -diagonal grid system?
Wed, Feb 11, 2009 at 4:24:47 PM
Curtain Grid Problems [ 1 2 ]
Wed, Apr 10, 2013 at 5:57:45 AM
19
Multi Segment Grid Line Bubble Issue
Wed, Dec 11, 2013 at 2:52:11 PM
curtain grid angle
Wed, Feb 11, 2009 at 4:27:26 PM
Curtain Grid Removing Segments
Mon, Jul 2, 2007 at 1:05:12 PM
Page generation time: 0.4318
