Forums >> Revit Building >> Technical Support >> changing the section symbol
Wed, Dec 23, 2009 at 9:10:06 AM | changing the section symbol
schnoodels
Is there a way to vhange the head symbol in section ? i made my own symbol as an annotaion family file and loaded it but still can't find it in the list of changing the head style of the section.
is there a way i can load my own symbol??
i can really use some help on that !! thanks!
Wed, Dec 23, 2009 at 9:16:11 AM | changing the section symbol
ChChChChela
ChChChChela Avatar
Yes there is.  Go to components and upload the file you created.  Then in a section view where you have a section cut symbol click on it:
>Right click>element Properties>edit/new>click on the arrow under "section tag"
You should find your customized tag and click on that.  Hope this helps :-).
Wed, Dec 23, 2009 at 9:31:31 AM | changing the section symbol
schnoodels
thanks for your help, i loaded it into components but it still won't show up on the section tag list ...
any other suggestion?
Wed, Dec 23, 2009 at 10:01:00 AM | changing the section symbol
ChChChChela
ChChChChela Avatar
Hmmm...when you created the section tag, did you make it as an annotation symbol family?
Wed, Dec 23, 2009 at 10:57:15 AM | changing the section symbol
schnoodels
i did.... i copied one that works and changed it
How can I get a lumber section symbol?
Tue, Aug 4, 2009 at 12:55:06 PM
I can't see an elevation symbol on a section?!
Thu, Mar 11, 2010 at 8:28:15 AM
symbol section!
Sun, Jul 23, 2006 at 4:48:38 AM
referenced section type keeps changing to "Drafting View: XXXDoNotUseXXX"
Wed, Jan 26, 2005 at 1:31:23 PM
new symbol from 2009 wont load as symbol in 2011
Wed, Jul 6, 2011 at 2:09:39 PM
Page generation time: 0.2829
