Forums >> Revit Building >> Technical Support >> beam spacing in beam systems
Tue, Dec 22, 2009 at 9:50:20 PM | beam spacing in beam systems
coske
hey guys how r ya Smile
 havent been on here in ages, which most likely means im doin ok with revit...untill today...
 im trying to make beam system, which is goin all good, but i was wondering if its possible to have the beams set on the grid, or to have different distances between the beams, not just by default equal spacing...if that makes ne sence.
 all the best guys and foward thanx for reply
Wed, Dec 23, 2009 at 12:19:56 AM | beam spacing in beam systems
Warchitect
4 Stars: 5 Votes
Sounds like you should do a library object with a bunch of planes that set the distances however you want. Then you could set up a grid that does exactly what you want. Otherwise the "align too" is the only thing I can think of.
Wed, Dec 23, 2009 at 9:36:20 AM | beam spacing in beam systems
TKennedy
4 Stars: 8 Votes
If I understand correctly what you are wanting to do, all you need to do is select one of the beams in the system and unpin it. This will allow you to move that beam independently of the auto spacing (or delete it entirely).
Mon, Jan 11, 2010 at 6:32:09 PM | beam spacing in beam systems
coske
thanx guys greatly appriciated, Smile and it works Smile beers on me Smile
Meeting Beam Systems to Glulam Beam
Wed, Jun 20, 2012 at 10:34:16 AM
Beam Systems
Wed, Aug 13, 2008 at 11:42:00 AM
Sloped Beam Systems Q's
Mon, Nov 14, 2016 at 11:48:46 AM
Non-Planar/Sloped Beam Systems with Elevation Points?
Thu, Jun 14, 2007 at 12:11:36 AM
Beam Systems
Wed, Feb 8, 2006 at 2:00:42 AM
Page generation time: 2.8407
