Forums >> Revit Systems >> Technical Support >> How do you change a "generic model" family into a "mechanical equipment" family?
Tue, Dec 22, 2009 at 12:58:20 PM | How do you change a "generic model" family into a "mechanical equipment" family?
jstahl
jstahl Avatar
I have created a few families as "generic models" and I need to change them to "mechanical equipment" The families have duct, pipe, and electrical connections. I'm Really trying to avoid redrawing them.
Tue, Dec 22, 2009 at 1:01:11 PM | How do you change a "generic model" family into a "mechanical equipment" family?
jstahl
jstahl Avatar
Nevermind... I just answered my own question.
Tue, Dec 22, 2009 at 1:09:02 PM | How do you change a "generic model" family into a "mechanical equipment" family?
Thread Post Kudo! #3
4 Stars: 205 Votes
You should put the answer here for the other guys with the same problem.... Settings>Family category And Paarameters>CryingSelect the Category you want)....
Fri, Apr 6, 2018 at 6:12:07 PM | How do you change a "generic model" family into a "mechanical equipment" family?
sleeknub
What about for a modeled in place family?  I'm not seeing how to make that solution work in that case.
Fri, Apr 6, 2018 at 6:18:19 PM | How do you change a "generic model" family into a "mechanical equipment" family?
sleeknub
Never mind, this basic method does work.  I'm using a newer version of Revit than was available at the time of the original posts, so that might account for the minor difference.
I selected the model, clicked "Edit In-Place", then clicked "Family Category and Parameters" which is under Modify>Properties.
Possible to change Family category to "Roof"
Mon, Aug 12, 2013 at 2:32:36 PM
How to make a "Model in-place" a "Family"
Thu, Mar 17, 2011 at 5:07:59 PM
changing the "family" and "type" names
Mon, Apr 2, 2007 at 5:33:49 PM
tagging by "family name" and "family type"
Mon, Jun 1, 2009 at 8:54:54 PM
Annotations nested inside a wall hosted equip family: Cant see the annotation
Wed, Aug 20, 2008 at 6:37:31 PM
Page generation time: 1.5590
