11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> how to see upper levels dash lines at the ground floor?
2 Posts No Rating |
hi i cant find how i will show upper floors dash line for example i have a bridge at the first floor which is standing on the coloumns when i am on the ground level i want to see extension of bridge on the ground level with dash line?how we will show the upper parts dash line on the ground floor plan?
15 Posts No Rating |
If you can't get view that you want using the view properties. you can go to view properties and set underlayment for the level above. (whatever it is for you) then you will be able to see the level above. Now go to detail lines and use the pick tools to place a dashed line on the geometry above. If you lock them to the lines above they will move with any changes later. When done go back to view properties and shut your underlayment off. Hopefully this helped.
12 Posts No Rating |
I recently ran across the following video tutorial which I think also describes jmickle's solution. Thanks to the Revit Kid for the tutorial: http://www.screencast.com/users/TheRevitKid/folders/Video%20Tutorials/media/99b626a8-6fd7-4829-8d9c-ea042e168e17
still flailing with RAC 2011 |
2 Posts No Rating |
thank you very much this is very helpfull
Ground lines |
Mon, Jun 13, 2011 at 1:32:56 PM
Ground Level 0'-0" has changed!!! |
Fri, Jan 23, 2015 at 10:35:19 AM
Faint lines showing from ground floor on first floor |
Sat, Mar 10, 2012 at 4:40:33 PM
First floor slab or ground floor ceiling? |
Fri, Aug 30, 2013 at 7:41:03 AM
Wher is my Grounf Floor? |
Mon, Mar 17, 2008 at 6:45:29 PM
