Forums >> Revit Building >> Technical Support >> From Max to revit
Sat, Dec 19, 2009 at 11:51:47 PM | From Max to revit
Altezza1
I have created an editable poly in max and im trying to import it into revit. Is it possible to use this shape like a revit massing, because I want to apply walls and floors to the surfaces. I would of used massing in revit, but it just didn't give out the desired shape that i needed. Any help??
Sun, Dec 20, 2009 at 8:19:59 PM | From Max to revit
Juzza
Juzza Avatar
I've done a few .max models into revit families this is a great walkthru if your having troubles with the import side of things: http://revitunplugged.blogspot.com/2008/10/max-2-revit-coolest-tip-ever.html
As for converting it to a Mass, I don't think it's possible not that I've tried mind you... But the max models are imported via a DWG file & I've found there's very little you can change on them once they're imported to revit. Assigning materials to layers is about the extent of it. Let me know if you have any luck tho.
Mon, Dec 21, 2009 at 5:41:42 AM | From Max to revit
4 Stars: 205 Votes
I think You should read the HELP menu first....
Mon, Dec 21, 2009 at 5:47:46 PM | From Max to revit
Juzza
Juzza Avatar
Huh, Help file??? That's crazy...
Revit FBX causes 3DS Max to crash
Wed, Aug 10, 2016 at 6:02:27 PM
render my walkthrough in 3DS MAX
Tue, Apr 23, 2013 at 2:07:40 PM
MAX TO REVIT?
Tue, Feb 10, 2009 at 8:38:48 PM
Revit bring into 3ds Max [ 1 2 ]
Sat, Dec 25, 2010 at 6:24:33 PM
17
Revit to 3d Max FBX [ 1 2 ]
Wed, Dec 1, 2010 at 8:52:13 PM
17
Page generation time: 5.4803
