23 Users Online (21 Members):
Forums >> Community >> Newbies >> Item Too High to Show in View
23 Posts No Rating |
I've created some duct that runs along the ceiling of my basement. When on the ground (or close to it) it shows up on my basement floorplan, but when I move it to the underside of the joists it disapears from the floor plan. Can anyone help me get it to show in the floor plan, even if it's near the top of the floor? Thank you
Couple of ways, Use a plan region to alter the cut plane height just in the section you need the duct to show. OR Set the cut plane so you can see the duct, then use the linework tool on the ductwork and adjust the cut plane. The ductwork should remain if done correctly. HTH.
Regards,
Chris.
Steel framing not showing on plan |
Wed, Sep 16, 2009 at 2:49:56 PM
DETAIL ITEM LIST NOT SHOW FULL LIST (2017) |
Fri, Nov 18, 2016 at 10:40:31 AM
Can I set text visibility to hide/show at different view detail levels? |
Tue, Sep 15, 2009 at 6:56:43 AM
How to get high quality output in revit2011 |
Fri, Feb 8, 2013 at 1:22:16 PM
11
Issue/revision line item showing up with revision cloud |
Tue, Aug 14, 2012 at 9:01:03 AM
