Forums >> Revit Building >> Technical Support >> Transparent Background
Wed, Dec 16, 2009 at 10:55:40 PM | Transparent Background
susiearch
Is there a way to make the background of a rendering transparent, so that when I bring it into Photoshop I can put a sky behind it and not have to cut out the background?
Thank you
Thu, Dec 17, 2009 at 3:01:42 AM | Transparent Background
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Please do a search of the forum next time.  This is a very FAQ...
Simply export to PNG or TIF and the resultant export will have an alpha channel for the background which you can turn off...
Regards,
Chris.
Wed, Apr 3, 2013 at 1:44:22 PM | Transparent Background
Spletz
It's an FQ because it's not exactly flear how this works.  Sometimes it does, sometimes it doesn't.  I have a transparent PNG and when I import it into an elevation - no go.
Wed, Apr 3, 2013 at 1:57:07 PM | Transparent Background
Spletz
So it's not as simple as many many post say.  Transparency to revit is a binary state.  Either it's 100% transparent or it's white.  In order to get to this state - say for an underlay sketch you want to use, you need to delete the background using the erase background tool, then change the mode (assuming photoshop here) from grayscale to a DUOTONE.  Then you export to web as a PNG.  This is the only way I've found to reliably get it working.
Print to PDF with transparent background!
Tue, Jan 25, 2011 at 8:12:03 AM
Transparency problem. Inserting tif's for decals, the transparent background...
Thu, May 24, 2012 at 12:47:44 PM
Export floor plan to format with transparent background
Wed, Jul 15, 2015 at 1:22:24 PM
Transparent pdf
Wed, Feb 21, 2018 at 5:27:47 PM
Any way NOT to render a backround in Revit 2013 ??
Wed, Feb 27, 2013 at 1:57:02 PM
Page generation time: 0.0950
