Forums >> Revit Building >> Technical Support >> Wall Types w/Shaft Liner Panel
Tue, Dec 15, 2009 at 4:47:02 PM | Wall Types w/Shaft Liner Panel
jgfry
How can I create a wall type that has a shaft liner panel and/or insulation inside of the stud (Core) itself? See attached:
Tue, Dec 15, 2009 at 5:05:36 PM | Wall Types w/Shaft Liner Panel
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Just allow zones for the various layers of the wall.  You won't be able to include the stud profile in plan.  Detail this in afterwards or use a column if you have to include it in the model...
Regards,
Chris.
Tue, Dec 15, 2009 at 5:14:10 PM | Wall Types w/Shaft Liner Panel
jgfry
Sorry...I don't understand what you mean "allow zones for the various layers of the wall." Can you clarify that please?
Tue, Dec 15, 2009 at 5:17:57 PM | Wall Types w/Shaft Liner Panel
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
In the wall structure properties add layers for each of the sections.  If need be you could also add a layer for the flange of the Shaft Stud if need be...
Regards,
Chris.
Tue, Dec 15, 2009 at 5:27:47 PM | Wall Types w/Shaft Liner Panel
jgfry
Referring to my sketch, let me ensure I understand you:
1" air layer on exterior side
inside Core Boundary add a 1/16" flange (what would you suggest as function/material?), 1" gyp. bd., 2 7/8" metal stud) = 4" total thickness
2 layers of 5/8" gyp bd on interior side of wall
Is this what you are suggesting?
Thu, Dec 17, 2009 at 2:48:43 AM | Wall Types w/Shaft Liner Panel
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Please note I'm using metric in Australia...
Exterior
Optional - 1/16" layer for metal stud flange (4)
1" Gyp. Board (4)
2 7/8" Metal Stud (1)
5/8" Gyp. Board (4)
5/8" Gyp. Board (4)
Interior
the 1" expansion joint/air layer would not be modelled you would just leave a gap between the walls.  You can't have an air layer external to the wall...
Then if you want you can place structural columns for the studs if you need that level of detail in the model or preferably just use a detail component on your details of the appropriate scale.
HTH.
Regards,
Chris.
Shaft demolision
Thu, May 6, 2010 at 3:46:50 PM
shaft cutting beams
Tue, Jun 2, 2009 at 7:47:18 AM
A Floor That Can't Be Penetrated by Shaft Opening
Thu, Feb 20, 2014 at 2:30:48 PM
Shaft Problem
Thu, Jul 12, 2012 at 5:20:52 PM
Shaft Visibillity
Wed, Jun 1, 2011 at 10:47:37 AM
Page generation time: 1.3068
