Forums >> General Discussion >> Revit Project Management >> Adding a gutter
Tue, Dec 15, 2009 at 11:49:54 AM | Adding a gutter
jlunny
I am working on a drawing with a complicated roof structure the roof is mono-pitched but also falls from front to back as well as one side to another. I am trying to attach a gutter to this roof however it will not work, when I select add gutter the arrow will not recognise this roof however I am able to put gutters on the simpler roofs in the drawing. Is there anything I should do or check to help with this problem.
Any help is welcome thankyou.
 J.Lunny.
Tue, Dec 15, 2009 at 12:48:21 PM | Adding a gutter
4 Stars: 205 Votes
You create that roof by "Extrusion"??? can you put some images about that roof and where do you want to apply the Gutters...?
Tue, Dec 15, 2009 at 3:25:59 PM | Adding a gutter
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Create the gutter profile as a fascia, and apply with the fascia tool.  Gutters can only be placed on horizontal roof edges...
Regards,
Chris.
Tue, Dec 15, 2009 at 5:06:50 PM | Adding a gutter
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
you could do it with solid sweep blends, it would take awhile
Gutter display on roof plan
Mon, Jun 11, 2007 at 3:47:21 PM
Gutter but what about gutter downpipe?
Mon, Feb 22, 2016 at 12:31:57 AM
Annoying gutter join
Mon, Aug 4, 2014 at 6:38:10 PM
CUSTOM GUTTER PROFILE
Wed, Mar 27, 2013 at 1:59:53 PM
sloping gutter
Thu, May 10, 2007 at 6:16:35 PM
Page generation time: 2.8243
