Forums >> Revit Systems >> Technical Support >> Valve Issues
Tue, Dec 15, 2009 at 8:25:48 AM | Valve Issues
AzTito
So im in the debugging stages of creating this butterfly valve and i ran accross this situation. The valve can be placed into the project fine and it adjusts size and everything. It looks like it should in all views except for the plan views where as in the image one can see that the symbolic lines shift off of the location of the valve. The connectors are in the correct place and when switched into "Fine" mode the valve shows up in place. Why would this be happening. Can someone give this file a look over and see what they may be able to come up with? Thanks. I had to change the .csv file to .xsl in order to upload it.
Thu, Dec 17, 2009 at 3:33:00 PM | Valve Issues
AzTito
Figured it out by going through each setting one by one and reloading it.  If it could help anyone out, Having the "Use Annotation"  setting selected was causing my issues.  Thanks to those who at least looked.
vertical valve
Mon, Jan 25, 2010 at 10:28:40 AM
Valve/Manifold Family
Tue, Nov 3, 2009 at 10:03:27 AM
motorized 3 way valve
Wed, Sep 5, 2012 at 1:06:25 AM
Trying to get created valve to insert into piping
Mon, Sep 10, 2007 at 9:40:25 AM
MEP Family Origin problem
Wed, Feb 10, 2010 at 10:23:03 AM
Page generation time: 1.6556
