Forums >> Revit Building >> Technical Support >> 3D path in Revit 2008?
Tue, Dec 15, 2009 at 4:49:57 AM | 3D path in Revit 2008?
Revin
Hi all,
I'm modeling a series of curves connected by straight elements that run in different directions. Sort of like an abused paper-clip, if you get what I mean. I'm doing it as a mass that is swept along a path, but Revit only gives me a 2-dimensional path option. Is there any way I could sort of drag certain points of the path to give it the 3D look I want. Or any other way to achieve this?
I see a few other users have asked this question in the past on these forums, but no answer has been forthcoming yet.
Thank guys!
Thu, Dec 17, 2009 at 6:51:40 PM | 3D path in Revit 2008?
pepsiqueen
pepsiqueen Avatar
did you try abusing the path in a 3d view? I am pretty sure there is a way to do this in newer versions of revit, but its kind of a pain and i always end up importing a sketchup model as a mass into revit.
I'd rather be riding at whistler. or highland. thats good too.
Fri, Dec 18, 2009 at 12:08:05 AM | 3D path in Revit 2008?
Pavan
Pavan Avatar
4.5 Stars: 3 Votes
Yes...you can have a 3D path...there is a command "Pick Path" in the sketch mode of Solid Sweep. Depends upon your shape you can pick the path in 3D view. Check the attachments.
Pavan Reddy
Revit Manager
Intelligence is not always knowing the answers, it's always asking the questions.
Mon, Dec 21, 2009 at 3:33:00 AM | 3D path in Revit 2008?
Revin
Hi Guys,
Pavan, I've tried it in Revit, but my model was of a free-form-nature, and I resorted to modeling it in Sketchup and importing it into Revit. After spending 2 days trying to get it done in Revit, Sketchup sorted me out in 30 mins.
Thanks anyways, guys!
Exporting a walkthrough path from Revit Architecture 2008 to Autodesk Viz 2008
Tue, Nov 20, 2007 at 12:37:43 PM
How to export walkthrough path to Viz 2008. Need reply by 11/15/07
Tue, Nov 13, 2007 at 3:30:39 PM
3D path insteads of 2D path
Mon, Mar 28, 2005 at 9:23:38 PM
Sketch a path greyed out...can't alter sweep path
Mon, Jul 26, 2010 at 4:45:05 PM
how do i create a 3d path in revit 2009
Fri, Aug 27, 2010 at 9:44:52 AM
Page generation time: 1.8770
