Forums >> Revit Building >> Technical Support >> FILL PATTERNS
Thu, Sep 1, 2005 at 11:40:31 AM | FILL PATTERNS
CSAA1230
Is there a way to change the scale the Eart fill Pattern?
Thu, Sep 1, 2005 at 12:34:35 PM | RE: FILL PATTERNS
TomDorner
4.5 Stars: 25 Votes
No way to change it once it is loaded into Revit. However, Revit uses the same pattern definitions as AutoCAD with an added line for each definition. What you can do is import a new earth hatch definition, give it a name like Earth small hatch, then set the scale to be what it is you want. There is a bit of trial and error with the scale. Do any experimenting on a new empty project and write down the scale factors for the results that turn out the way you want them. Then in the active project and in your templates you can have just the good fill patterns. This site has a ton of fill patterns. Scott Brown even had at one time on this site all his scale factor settings for each pattern. (Scott Brown is one of the Revit gurus working at WATG in Orlando). Check the Revit help file for more info. Post again if you run into a glitch and someone can help you through it. HTH Tom
Perpsective Fill Patterns
Mon, May 10, 2010 at 6:12:50 PM
Fill Patterns
Mon, Mar 10, 2008 at 6:40:09 AM
create/ convert hatch patterns (.pat) to revit fill patterns
Tue, Jun 2, 2015 at 11:29:00 AM
Fill patterns, where are they?
Tue, Mar 31, 2009 at 10:11:29 AM
Wall Fill Pattern question
Tue, Oct 23, 2012 at 8:39:37 AM
Page generation time: 0.0918
