Forums >> Revit Systems >> Technical Support >> Architectural Links
Mon, Dec 14, 2009 at 11:40:19 PM | Architectural Links
vinnygolfer
4.5 Stars: 4 Votes
i have a model that the architect gave me of a school. i imported the link into MEP 2010. and everything is working fine, except when i went to print a sheet all the information from the link prints very light. i can't figure out how to make it darker. i don't want the architects model to be as dark as what i have put in, but the walls are printing almost non-existant.
i ended up exporting the dwg's and printing with AutoCad to get the look i want. that can't be the best way.
Try to learn at least one new thing every day
Tue, Dec 15, 2009 at 6:38:19 AM | Architectural Links
Think visibility... VG.  The visibility of all items, including linked items, is controlled through VG.   I will bet the your MEPO template is set to show your linked file as screened.
Tue, Dec 15, 2009 at 6:54:18 AM | Architectural Links
vinnygolfer
4.5 Stars: 4 Votes
thanks for the response. i have been all through the VG tables and can't figure out what is set up wrong. every totorial that i have watched, tell me not to copy the walls when i do the copy/monitor part of loading the link. but do i need to copy the walls to get them to show darker. it's as if they are being set to half-tone but nothing is marked that way.
also you made a reference to the MEPO, where is that located in the VG.
Tue, Dec 15, 2009 at 8:12:01 AM | Architectural Links
vinnygolfer
4.5 Stars: 4 Votes
well the best that i could get revit to do was if in the print setup, i checked convert halftones to thin lines. at least now you can see the walls, but they are still too light.
Mon, Dec 21, 2009 at 4:05:44 PM | Architectural Links
Dingo46
Dingo46 Avatar
1 Stars: 1 Votes
If you go to View Proerties and change your Discipline to Architectural or Coordination, Your link will appear darker in that view. If you go to VG > Revit Links and change your discipline to Arch or Coord. it will make your link appear darker in all views....  uh  i think...
Gary
Mon, Dec 21, 2009 at 4:28:58 PM | Architectural Links
vinnygolfer
4.5 Stars: 4 Votes
thank you, i'll give it a try tomorrow.
Tue, Dec 22, 2009 at 7:50:16 AM | Architectural Links
vinnygolfer
4.5 Stars: 4 Votes
thanks, i tried it and got the output that i was looking for.
Trouble converting links to groups
Tue, Oct 25, 2016 at 12:12:21 AM
Architectural Vs. Structural Linking
Tue, Feb 19, 2019 at 10:42:28 PM
Lights in MEP or Achitecture
Fri, Oct 28, 2011 at 3:01:38 AM
*URGENT * - Worksets & Links
Mon, Oct 12, 2009 at 5:51:32 PM
Links
Wed, Jul 28, 2010 at 7:07:06 PM
Page generation time: 0.0942
