Forums >> Revit Building >> Technical Support >> Wall type with punch through pattern
Mon, Dec 14, 2009 at 5:55:06 PM | Wall type with punch through pattern
dguich
I would like to place a repeating pattern matrix on a wall type. I also want it to be able to fill the pattern as I stretch or shrink the wall. Is there a way to create this in the wall type creation window? For example: I have a repeating pattern such as a flower that I want to place on a wall and would like it to fill in as I stretch the wall or shrink the wall.
Tue, Dec 15, 2009 at 6:59:24 AM | Wall type with punch through pattern
The only tool you have for this is the coarse fill pattern that you can set for each wall type.
Show model pattern in 3D view
Sat, Dec 6, 2008 at 10:01:16 AM
11
Would like to get 3D .POB files from Punch! program into Revit.
Tue, Aug 4, 2009 at 2:10:23 PM
Changing wall types midmay through wall
Mon, May 22, 2006 at 1:45:33 PM
Opening Tool + Phases
Wed, Jan 4, 2006 at 4:14:31 PM
Wall's surface pattern goes through the reveal in elevation view
Thu, Jul 12, 2012 at 10:46:52 AM
13
Page generation time: 0.9436
