Forums >> Revit Structure >> Technical Support >> Rebar on Wall Based Family Questions
Mon, Dec 14, 2009 at 4:49:24 PM | Rebar on Wall Based Family Questions
rex916
Hello,
I am trying to create a family that when we bring it into a project, it will show all the correct struff in elevation (rebar representation and openings).  So I started a wall based family that shows openings in a cmu wall. This family also shows rebar representaion (filled regions) on the face of the wall. I placed the filled region on the work plane called Wall Edge.
My problem is that when I bring this into a project and insert it into a cmu wall: my rebar is showing up as a open rebar instead of solid. ( meaning I only see the outline of the rebar instead of seeing a solid line.) Does anyone know what I am doing wrong? Any help would be great.
changing type of a family from wall based to face based
Wed, Mar 3, 2010 at 8:24:37 PM
Placing Rebar in a CMU wall
Fri, Dec 5, 2008 at 5:18:38 AM
Placing Rebar/Strand in Walls
Fri, Apr 10, 2015 at 4:04:48 PM
Is it possible to make a line-based family wall based?
Wed, Jan 5, 2011 at 1:00:21 PM
Revit 2013 family from wall based to flor based
Mon, Feb 4, 2013 at 6:56:51 AM
Page generation time: 1.6638
