25 Users Online (23 Members):
Forums >> Revit Building >> Technical Support >> Change Door Type
1 Posts No Rating |
I'm not sure if this is the right forum to ask this so forgive me if it's not. I'm an autocad veteran that is fairly new to revit. I have basically just gone through all the supplied tutorials in architecture 2010. Now I'm using a set of existing floorplans of a store in a local mall as a project to build my revit skills. So far I've only got the massing and exterior walls done, not much I know. I'm trying to add doors to the front of the store, but the only door available from the type selector is "single flush". I started with the supplied "Commercial-Default.rte" template. I've loaded "Doors/Curtain Wall-Store Front-Dbl.rfa" into the project but it will not show up in the type selector. What am I missing? Also, are there any IRC channels with really bored revit users that like to answer questions? I have a feeling that I'm going to have many more.
The curtain wall door families can only be used in an actual curtain wall. If you con't have a curtain wall, you will have to load a different family.
Door tags and Door Type ID |
Wed, Jul 10, 2013 at 1:40:25 PM
Same Door Type, Different Frame Type |
Thu, Jul 24, 2008 at 3:16:26 PM
creat double door w/ adjustable swing |
Mon, Apr 27, 2015 at 1:30:05 PM
Need Assistance with Door Materials |
Fri, Feb 22, 2008 at 1:11:01 PM
Door Tag Parameter-Need it to be the door opening number, not the door type..... |
Thu, May 7, 2009 at 4:09:39 PM
