Forums >> Revit Building >> Technical Support >> call outs and detail lines best practices?
Sat, Dec 12, 2009 at 2:17:04 PM | call outs and detail lines best practices?
greg1970
We've been workingin Revit now for about two weeks and things have had their ups and downs but we are getting it.  However, I have not been able to accomplish the following:
I want to cut a section of a wall at say 1/2" = 1' and add some detail that should be present at that scale and then I want to make a callout in that section with the detail lines that I just added so that when I go to the callout I have those lines I just added plus the new ones that I will add to fully detail the item.  However, my lines do not transfer from the section at 1/2" to the detail callout.  How do you do that so that you are not constantly copying and updating two or even three drawings every time there is a change withing the views of the callouts and sections.
Sat, Dec 12, 2009 at 4:42:12 PM | call outs and detail lines best practices?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Detail lines are 2D elements that are view specific.  A callout is a new view and only model elements will persist.  If you want to achieve that, group the detail lines, then copy and paste aligned in your callour.  That way any changes made to the group will be perpetuating everywhere the group is.
HTH.
Regards,
Chris.
Sat, Dec 12, 2009 at 5:13:15 PM | call outs and detail lines best practices?
greg1970
and when I paste the group the scale is autmatically delt with.  Like if I go from a 1" to a 3" detail?
Tue, Dec 15, 2009 at 8:46:41 AM | call outs and detail lines best practices?
MARS1276
1 Stars: 1 Votes
yes since the scale is view-dependant rather than model-based
Call outs withing call outs
Sun, May 10, 2009 at 3:35:42 PM
Call outs in Revit
Wed, Jun 11, 2008 at 8:39:23 AM
Grid Head/lines in Call Out Views
Sun, Dec 3, 2006 at 5:38:37 PM
Call Outs
Sat, Feb 27, 2010 at 5:23:33 AM
Strucutral Columns VS Walls in Call outs
Mon, Aug 16, 2010 at 8:17:05 AM
Page generation time: 0.6331
