Forums >> Revit Building >> Technical Support >> Roof fascia curves in plan and elevation
Fri, Dec 11, 2009 at 12:42:07 PM | Roof fascia curves in plan and elevation
yriggie
Does anyone know how to create a roof fascia that curves 2 directions?  I haven't been able to do it with the roof fascia tool.  I thought maybe creating a thin roof outbourd of the edge of the roof would be a quick workaround but roofs don't let you include a profile, which I need.  Any ideas?  I'm using Revit 2009.
Fri, Dec 11, 2009 at 1:05:33 PM | Roof fascia curves in plan and elevation
2005Mark
3.5 Stars: 2 Votes
What do you mean curved in two directions Curved in plan or elevation?
Mark
Fri, Dec 11, 2009 at 1:14:58 PM | Roof fascia curves in plan and elevation
4 Stars: 205 Votes
Some images of what you need i think will help...
Fri, Dec 11, 2009 at 3:27:55 PM | Roof fascia curves in plan and elevation
erland73
erland73 Avatar
4.5 Stars: 85 Votes
You can try it with an in-place family-->roof category-->solid sweep.....but as Typhoon said, an image could help better...
Fri, Dec 11, 2009 at 4:23:25 PM | Roof fascia curves in plan and elevation
yriggie
The problem with a sweep is that it only lets you create a path in 2D, not 3D.
 I've attached a revit file for reference.
Fri, Dec 11, 2009 at 6:36:40 PM | Roof fascia curves in plan and elevation
yriggie
Sat, Dec 12, 2009 at 5:19:11 AM | Roof fascia curves in plan and elevation
4 Stars: 205 Votes
Yep, now i see what you want, use the create in place like Erland said and it's done...
Sat, Dec 12, 2009 at 4:46:44 PM | Roof fascia curves in plan and elevation
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
A sweep can have a 3D path, but only when you use the pick command for the path...
Regards,
Chris.
Sat, Dec 12, 2009 at 4:54:44 PM | Roof fascia curves in plan and elevation
erland73
erland73 Avatar
4.5 Stars: 85 Votes
"The problem with a sweep is that it only lets you create a path in 2D, not 3D." What do you mean by this?.....
Sun, Dec 13, 2009 at 1:40:44 PM | Roof fascia curves in plan and elevation
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
LIKE SPOT SAID, FOR THE PATH YOU WILL HAVE USE PICK 3D EDGES.
J. Allen Ball
Revit Architecture 2010 Certified Professional
Adding fascia to curved roof.
Mon, Dec 13, 2010 at 9:21:59 AM
Vertical Fascia on Roof by Extrusion - Is it possible?
Wed, Dec 4, 2013 at 9:44:49 AM
How to miter a fascia on a sloped roof?
Fri, Aug 24, 2012 at 7:48:23 AM
Roof Fascia On Negative Sloped Roof
Wed, May 15, 2013 at 9:47:35 AM
roof fascia
Fri, Jul 27, 2007 at 1:29:36 PM
Page generation time: 2.2398
