Forums >> Revit Building >> Technical Support >> Hiding Linked Model Levels/Grids - Over time they keep coming back! :(
Thu, Dec 10, 2009 at 6:31:07 PM | Hiding Linked Model Levels/Grids - Over time they keep coming back! :(
snofreek
I thought I was onto something at one point, but we still seem to be battling with multiple level lines/column grids on top of eachother as a result of linked models each coming in with their own levels/grids.
I read on the forums that if all linked Revit models have these elements (and only these elements) on the workset “shared levels and grids” it’s possible to link models and select not to open this workset.  This loads the link, but eliminates the duplicate level/grid lines of that particular link for all views.  If this process is followed for all links all the time, then the only grids we’ll see are the “live” grids in the main model.  Right?  Well, it was working at first, and I’m not sure why it doesn’t anymore, it could be that over time “reloading” instead of “reload from” resets to show all worksets.  (my suspicion)
Got any ideas?
save to central
Thu, Dec 10, 2009 at 6:51:18 PM | Hiding Linked Model Levels/Grids - Over time they keep coming back! :(
Use VG in your views to control what shows in linked models.
Can't Get Copy Monitor to Work for Grids and Levels
Fri, Feb 21, 2014 at 4:55:28 PM
Overriding grids of a linked model in view
Wed, Oct 30, 2019 at 10:46:45 AM
Hiding linked Walls by Wall Type???
Wed, Oct 12, 2011 at 2:48:13 PM
Revit 2009 Importing Structural Dwg
Thu, Aug 25, 2011 at 1:35:55 PM
Errors when Copy/Monitoring Levels
Tue, Jan 30, 2018 at 4:27:02 PM
Page generation time: 3.5753
