Forums >> General Discussion >> Revit Project Management >> Symbol Text
Thu, Dec 10, 2009 at 5:27:49 PM | Symbol Text
TONY121
My firm uses a custom elevation detail symbol which calls out a specified detail, my problem is that when I rotate the symbol based on the elevation location on a structural plan the text rotates along with the symbol. So when the symbol is rotated 180 degrees the text appears upside down.  Is it possible to have the text remain oriented correctly while the symbol can be rotated?
Thu, Dec 10, 2009 at 5:39:08 PM | Symbol Text
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Family Properties-->Category & Parameters-->Keep Text Readable to ON.
BTW, why aren't you using true elevations instead of symbols?
Regards,
Chris.
sloped annotation symbol text
Mon, Aug 15, 2011 at 8:04:20 PM
Annotation Symbol Text - Keep Vertical?
Thu, Dec 15, 2011 at 3:23:42 PM
Centerline Symbol in Text [ 1 2 ]
Wed, Jun 30, 2010 at 8:29:06 PM
19
how to type degree symbol in text
Mon, May 21, 2007 at 11:54:29 AM
Text Symbols? [ 1 2 ]
Tue, Apr 28, 2009 at 2:43:34 PM
22
Page generation time: 0.2878
