Forums >> Community >> Newbies >> Wall Footings
Thu, Dec 10, 2009 at 3:51:18 PM | Wall Footings
wsquiers
I have a multi layered cmu wall:  an 8" block exterior and a metal stud furring wall on the interior.  I unlocked the stud and gyp. board layers so I could slide them up to lie on top of the concrete slab while the cmu continues down to a concrete footing. When I try to place the footing I get two of them; one for the 8" cmu and another for the stud and gyp. wall.  I can't figure out how to get a single footing for the 8" wall.  I tried to make a separate stud and gyp. wall but when I insert window they will only cut the cmu wall.
help
Thu, Dec 10, 2009 at 5:04:34 PM | Wall Footings
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Do the reverse.  Unlock the CMU layer and drag it down rather than dragging the finishes up...
Regards,
Chris.
Thu, Dec 10, 2009 at 5:16:52 PM | Wall Footings
wsquiers
Thanks but no luck, still produced 2 footings.  Could be operator error?
Thu, Dec 10, 2009 at 5:34:13 PM | Wall Footings
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Okay, just had a play. (BTW, I don't use the wall footing tools as I found them pretty limiting).
The Wall footing will always be located at the actual base location of the wall and not at the base extension distance.  So your original setup of lifting the stud and gypsum up is the correct approach.  That said, I just applied a wall footing to a wall using this exact setup and it worked fine and I only have 1 footing correctly located at the bottom of the CMU (Blockwork)...
Regards,
Chris.
Tue, Dec 15, 2009 at 9:36:43 AM | Wall Footings
wsquiers
Thanks again, but still no luck.  Initially I thought the problem might be the fact I had the base level of the wall at the floor line with a base offset of -24".  I changed it so that the base level was at the top of footing and moved the stud/gyp. up to the floor but still got two footings.????
Tue, Dec 15, 2009 at 10:19:52 AM | Wall Footings
jmickle
not totally sure why it is creating a footing at both levels, but if you do separate your walls until you figure it out, place both walls then join them. Then your windows and doors should cut both walls.
Tue, Dec 15, 2009 at 1:50:31 PM | Wall Footings
wsquiers
I'll give it a shot, thanks
Tue, Dec 15, 2009 at 2:16:22 PM | Wall Footings
wsquiers
Worked perfectly, thanks for the heads up.
isolated footings not showing up
Wed, Jul 18, 2012 at 1:17:11 PM
Revit creates two footings at compound wall
Mon, Apr 27, 2015 at 9:22:17 AM
Wall Footings
Mon, Sep 15, 2008 at 4:21:41 PM
Footings for Slab Foundation
Tue, Oct 30, 2007 at 7:05:08 AM
Footings
Mon, Dec 17, 2012 at 1:31:16 PM
Page generation time: 0.5215
