Forums >> Revit Building >> Technical Support >> Revit renderings - colors are off
Thu, Dec 10, 2009 at 11:48:23 AM | Revit renderings - colors are off
MarkBryanDesign7
I am working for a firm trying to use Revit for rendering exterior elevations. I have created new materials using image files, and created materials using the color with a bmp as the texture. In all the renderings the sun settings throw off the colors because of the "yellowness" of the sun. And adjusting the exposure etc is a pain becuse I am not sure what settings to use. Any suggestions?
Thu, Jun 30, 2011 at 2:36:19 PM | Revit renderings - colors are off
ChelesaTheRad
What I have found to help is to darken the RGB in the materials library darker than the actual color you are trying to render. This will take a few test renderings, on draft setting, to get the colors right. If you are using a material from the materials library and it has a color to it then you might need to fade the image or turn the image off completely (depending on what type of material you are rendering) make sure you adjust the bump as well to get a more realistic texture.
Thu, Jun 30, 2011 at 8:08:44 PM | Revit renderings - colors are off
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
In the Exposure Settings of the Rendering Dialog,
Adjust the White Point to be Cooler.  Or try a different time of Day, earlier morning and late afternoon there will be more yellow/orange in the image.
Most rendering in Revit is tweaking, most times though, I get the quality in Revit and then take to photoshop and adjust colours, add entourage etc...
Regards,
Chris.
Compent colors don't show up in renderings
Tue, Apr 24, 2007 at 12:54:18 PM
Showing people in renderings
Wed, Apr 23, 2008 at 8:13:20 AM
Colors and Printing
Thu, Jul 19, 2012 at 10:11:31 AM
Best approach to Photo Realistic Renderings? [ 1 2 ]
Thu, Dec 13, 2012 at 3:40:13 PM
15
Color of Materials in Renderings
Tue, Jul 17, 2012 at 10:35:19 AM
Page generation time: 1.7582
