13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Room seperation
5 Posts No Rating |
Can I control wether room seperation lines are visible during plotting? But still keep it visible in views. How please? Help. version : revit arch 2009
You can't. Either they are on or they are off. Even when off, they still work.
5 Posts No Rating |
Thank you. Figured that. Was just hoping for a miracle.
Semi work-around is to make it white. You won't see it, but it will highlight when you hover your mouse over it.
The answer is probably to develop more views. I generally have one view called a "working" view where the room separation lines are on, then another view called a "printed" view where they are off. The "printed" views should have their VG set once and then left alone. The working views you can mess with since they are not part of the printed documentation.
room seperation lines |
Mon, Mar 8, 2010 at 5:01:05 PM
Rooms - editing room seperation lines |
Fri, May 16, 2008 at 5:29:29 PM
Room seperation lines |
Fri, May 12, 2006 at 5:19:35 PM
Mysterious Room Seperator |
Fri, Feb 3, 2012 at 2:39:06 PM
Room seperation at center of wall? |
Sun, Jan 7, 2018 at 1:38:23 PM
