Forums >> Revit Building >> Technical Support >> BIG curtain wall room bounding problem!!
Thu, Dec 10, 2009 at 4:57:39 AM | BIG curtain wall room bounding problem!!
Arno
We use curtain walls for interieur office system walls.
The problem is that the room bounding line in a curtain wall is in the center and not on the face of a panel. Resulting in a wrong square area of the room.
Is there a way to place the room bounding on the face of a curtain wall, like a 'normal' wall.
If this isn't posible we need to put room seperation lines in all rooms!!!
Thanks
Arno
Thu, Dec 10, 2009 at 6:34:10 AM | BIG curtain wall room bounding problem!!
You need to learn to use your HELP.  Revit's help is very good and explains a lot more than we ever got with CAD.  Read this topic: Changing the Room Area Boundary Location
Mon, Dec 14, 2009 at 9:02:37 AM | BIG curtain wall room bounding problem!!
Arno
This doesn't work on curtain walls!!!! And i do use Help!!
Mon, Dec 14, 2009 at 9:31:31 AM | BIG curtain wall room bounding problem!!
My advice was not a criticism.  Your question did not indicate that you understood room boundry calculation settings.
And you are right, room boundries on curtainwalls only appear to be at the curtainwall definition line.   You can create your curtainwall so that this line is on one face and not the center.
Fri, Jul 28, 2017 at 4:03:50 AM
13
Curtain Wall & Room Bounding Dissapeared
Mon, Jun 27, 2011 at 9:36:36 AM
room bounding parameter in wall
Fri, Jun 27, 2008 at 10:17:07 AM
Room bounding...
Sat, Jan 6, 2007 at 7:39:42 PM
Room Bounding - Room area changes, then changes back for no reason!
Wed, Apr 28, 2010 at 6:22:40 PM
Page generation time: 1.7860
